| Cummins Low Flow Cooling - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: CAT, Detroit, and Other engine related Help... (/forumdisplay.php?fid=72) +--- Thread: Cummins Low Flow Cooling (/showthread.php?tid=4070) |
Cummins Low Flow Cooling - RocketScott - 01-28-2019 I'm tripping through my truck fixing all the little things right now 1989 Pete 379, Cummins NT855 444xt Right now I'm rebuilding the oil cooler and that led to working on the cooling system in general. Most of the hoses look pretty beat so I'm replacing them The upper hose is 1" and the lower is 1-1/4", so it's a 'low flow' system. I have heard that there were some problems with those and that a conversion was possible to high flow I haven't seen a good explanation of why the change was needed (or the service bulletins from Cummins on how to do it). My truck has worked fine for the past 5 year but it would be nice to know why the change was engineered and how it was done RE: Cummins Low Flow Cooling - Hammerhead - 01-30-2019 There aren't too many 444's around anymore. I drove one back in the day, but I was too inexperienced at the time to remember much about this... And I was the second driver on the unit. RE: Cummins Low Flow Cooling - Soulreaver0102 - 02-04-2019 You can convert them from what I have read. It requires several different parts to convert including a different radiator. The main issue I have read is just they overheat. If your not having an issue with overheating then I wouldn’t worry about it. Keep in good thermostats and keep radiator clean. The parts to convert is normally pulled from a big cam 3 or lower. They was all high flow. The big cam 4 and up I think was all low flow. Haven’t read a whole lot on 444. I’m sure someone around with first hand experience will chime in soon. |
