| Weller reman transmissions - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Other truck related Help... (/forumdisplay.php?fid=71) +--- Thread: Weller reman transmissions (/showthread.php?tid=4086) |
Weller reman transmissions - Mrkentee - 02-01-2019 What’s the general consensus on Weller reman transmissions? RE: Weller reman transmissions - Rawze - 02-01-2019 (02-01-2019 )Mrkentee Wrote: What’s the general consensus on Weller reman transmissions? I got weller re-man rears,... no issues. Was less money than if I had rebuilt them myself by the time I got all new bearings, gears, etc. RE: Weller reman transmissions - Chamberpains - 02-02-2019 Yup, what he said. Pop yours out, swap the jewelry and slide the new 1 back in. Rebuilding them yourself is easy enough. Getting all the parts you need in a timely manner is where it really goes wrong. You'll get a part today a part tomorrow 5 or 6 on back order. Weller is the way to go. RE: Weller reman transmissions - Moose - 02-02-2019 I got 150k on an 18918b from them, shifting & splitting got better as time went on. It's doing fine now and I'd get another from them. The price and lack of downtime is worth it to me. RE: Weller reman transmissions - stevesparts - 02-02-2019 I've had a Weller with well over 500,000 on it it has performed very well.(13sp) but i might have hurt the input shaft with a bad shift under a load(my fault :( ) but they work great and save you the down time from getting yours rebuilt. |
