| injector leak test - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: injector leak test (/showthread.php?tid=412) |
injector leak test - arttrans13 - 05-10-2016 hey rawz,, on your video u explain how to determin wich injector is leaking between a and b=#3 between b and c =#1 between c and a = #3 how about 4 5 and 6 RE: Rawze's Daily blog... - ahm700 - 05-10-2016 (05-10-2016 )arttrans13 Wrote: hey rawze,,,,on your injector leak test u mentioned the sequence of injestors 1 thru 3 being test a b c, but how about the position for the other set of injectors? do i move the test kit to the second actuator and consider a b c to be injestors 4 5 6?? If I remember right 1st acturator is for front 3 injectors and last acturator is for the back 3 RE: injector leak test - RTRUCKING48 - 05-10-2016 (05-10-2016 )arttrans13 Wrote: hey rawz,, on your video u explain how to determin wich injector is leaking between a and b=#3 between b and c =#1 between c and a = #3 how about 4 5 and 6I think you have to set the tool on the second bank of injectors and do the same procedure as the first bank RE: Rawze's Daily blog... - arttrans13 - 05-10-2016 Thank u Rawze,, im actuly looking for the sequence of where does 4 5 6 fall in,,example. # 1 is betweenb and c . And #2 is between a and c. And # 3 is between a and b, where is 4, 5 and 6. Fall in???? And thanks for thw previous response always appreciated,, RE: injector leak test - arttrans13 - 05-10-2016 (05-10-2016 )RTRUCKING48 Wrote:(05-10-2016 )arttrans13 Wrote: hey rawz,, on your video u explain how to determin wich injector is leaking between a and b=#3 between b and c =#1 between c and a = #3 how about 4 5 and 6I think you have to set the tool on the second bank of injectors and do the same procedure as the first bank so i guess that would be the #4 between b and c #5 between c and a and finally #6 a and b ?? technically speaking? RE: injector leak test - Peterbilt387 - 05-10-2016 Just did a 6pack on mine,i did the leak test too and you better put attention, you may have more than one injector leaking, how many miles on that truck? |
