| ISX605 high oil temp - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: ISX605 high oil temp (/showthread.php?tid=4148) |
ISX605 high oil temp - smitty210 - 02-13-2019 This is on a Motorhome Diesel Pusher, brand new 14k miles. The owner has been plagued with high oil temp alarms and engine shutdown alarms. Here is his latest post from our MH forum. Looking for any thoughts from you guys. Yesterday, I needed to get from Casa Grande, AZ to Yuma, AZ. This is 180 miles of Arizona flat with a pretty good mountain climb right before you descend down into Yuma. I took everyone's advice and decided to avail myself of the SPEEDCO located about 2 miles from where I was staying at Exit 200 on I-10. As an aside, I got the $25 oil analysis (which I don't know how to interpret at this point) but my charge was $480 for 52 quarts of Rotella (so $455 for the standard oil, lube, and 2 filters (no genny service) that used to run me about $330). Anyhow, 2 hours later, I was on my way to Yuma. You remember that I have been told by Cummins and Spartan to run it like I stole it, and that meant that I simply used it the way that I always use it. I turned the ACC off, turned the Valor TPMS on, and set the cruise for 69 mph (75 mph speed-limit) and off we went. Set my dash so that it always showed me oil temperature. Over maybe the first 40 miles, the oil temperature gradually increased from cold to 250, and then steadily increase to 259 degrees. And at 259 degrees, the temperature stabilized and then began dropping a little at a time for 10-15 miles until it got down to 248 or 245 and then up and down a little and eventually got down to 239 degrees, and then hovered near there. We stopped at a rest stop for lunch and the engine oil temp never got up much past 255 after lunch and usually in the 240-245 range. That is the way that it ran. No Shut downs, no CELs, and the temp varying by terrain up and down from 240-250 let say. As I said earlier, there is a pretty good rise right before you go into Yuma on I-8, maybe 1000-1500 feet or more (?) with most trucks down around 35-40 mph. I left the cruise set at 69 and we passed a bunch of trucks in 6th, and then the coach downshifted to 5th and we were down to maybe like 50 and the oil temps started up again (coolant moved from 180 +/- to 183 +/-, and this time, did not stop at 259, but hit 262 at which point I got a CEL (no Shut-down icon) but a CEL (with checkmark). I let the CEL show and at this point foot-fed the diesel but basically kept pouring the juice to it, and we climbed for maybe another 30 seconds to a minute when we crested the hill, and the CEL went off, the oil temp stayed at 262 for ~ a minute and as the CEL went off, oil temp started to fall as we descended the back side of the mountains. So, its pretty clear that the CEL light comes on if you go past 260 degrees, and my guess is that the oil thermostat open at 259-260 and stays open down to about 240 where it closes or stays open thereafter. If the temp exceeds 260 and the thermostat doesn't open fast enough, then the CEL comes on until the temp falls below 259. Now, I am sure that is what my engine did and how it was working. Whether that is right or wrong is a matter we are discussing. My sense is that this X15 engine is a very different horse than the 450 ISL. Cummins has been quite sure that this engine runs hotter than other engines in their line and the oil cooler and thermostat are set higher than other Cummins engines. Now, my experience confirms what I have been told, but I dont think this 605 should be throwing any codes even when climbing a mountain so I am going to keep pursuing this whole conundrum. My opinion is that the thermostat should probably open at 250 instead of 260 or the ECM is programmed too tight to the 260 degree opening point. Maybe a rapid rise on a big upgrade leads the thermostat to be late in opening. Not sure. Otherwise, the X15 handles normal Arizona driving just fine, but that mountain CEL makes me intent to keep asking questions. I will be communicating with Spartan and Cummins again today with this new information and see what they say. ...... I have another call into Spartan and Cummins and have sent them a copy of my oil analysis which I will post up here also. They will call me back later today. I now understand that I got a clean bill of health on almost all aspects of the oil analysis, but I got two warnings on the oil analysis by SPEEDCO..... V40C and V100C which appears to be a reading of viscosity of the oil done at 40 degrees Centigrade and also again at 100 degrees centigrade. Haven't figured out if it is too much or little viscosity at this point but that will come next (Im betting on too much). No red line readings on anything. RE: ISX605 high oil temp - tree98 - 02-13-2019 First of all, throw that oil analysis from speedco out the window it's an absolute joke. Sounds to me like a problem with the oil thermostat. Could be sticking?? What did the idiots at Cummins say about it? Besides "drive it like you stole it" RE: ISX605 high oil temp - Rawze - 02-13-2019 (02-13-2019 )smitty210 Wrote: ... assuming for a moment that your post is somewhat truthful... FIRST OF ALL =---- YOUR "CUMMINS" STEALER IS A F%KING IDIOT AND SO IS THE DUMB-S#IT WHO WAS DRIVING IT AND POSSIBLY ABUSING THE HOLY-HELL OUT OF THAT ENIGNE!!!!!!! NEXT,.. WHO WOULD BE SO STUPID to drive that thing knowing it has high oil temp issues with such high oil temps going off and not backing off it until they found out what was actually wrong?!!?? --- IN THE MOUNTAINS AND HILLS FULL THROTTLE WITH OIL ALARMS GOING OFF? --- WHOEVER THAT IDIOT IS, THEY NEED THEIR HEAD EXAMINED AND A SWIFT KICK IN THE ARSSE #@# -- Did I say that out loud? -- YUP! Now, with that bit of idiotic wake-up call out of the way... First of all, As an example,... the ISX CM870 engine, the oil temp usually hovers around the 215 - 220 mark unless under a hard pull. Under a hard pull, it is not unusual to see the oil temp sitting ~ 40-F above the water temp(225-230~ish). Above 245-F is considered high, and THE TEMPS YOU ARE DESCRIBING, 260+ ARE WAY TOO HIGH -- So.... * The oil temp sensor could be bad. -- Replace the oil temp sensor + verify the oil temps seen in the dash are correct and not something wonky. Assuming the oil temps did reach those high numbers for a moment ... * BAD DELETE PROGRAMMING? (or incorrect factory program? where the HP is set too high for the vehicle?) WILL MAKE ONE HAVE EXCESS OIL TEMPS!!! -- That was my first thoughts, + the fact that there is a brain butcher around every corner these days willing to hack one up using severely bad programming methods. - If it is not deleted/de-mandated, make sure the program in the engine matches exactly the program required by the data-plate, and re-flash it to the latest update(s) while your at it. * Obviously, your descriptions would also point heavily towards a bad oil thermostat that is stuck OPEN?,.. or some complete idiot has removed it out of sheer stupidity?. * extreme excess boost levels from the turbo either due to bad programming or bad turbo controller... -- What is the boost pressure getting to max? - This also usually is accompanied by turbo alarms usually, but that was not mentioned. * {cm570/870/871} Bad timing actuator can make the oil get hot like that (due to too far advanced injection timing) - and will kill a piston after a while. * A spun bearing can make the oil over-heat like that,.. just another possibility. * {cm570/870/871} Could also be a bad ECM that is firing a timing actuator incorrectly (although very unlikely). Should be easily found with some testing. * It can also have a slipped cam in it... Have the cams wedged again to be sure this did not happen, and go from there. -- Lastly,... throw the speedco oil analysis speed-test machine crap in the trash can or use it in the bathroom next time you need to wipe your tootie off ,.. that is its only useful purpose. -- USELESS!. -- If you want an actual oil analysis,.. take a sample and SEND IT TO A REAL LAB!. RE: ISX605 high oil temp - Chamberpains - 02-13-2019 I don't see where this is a cm870... He states its a brand new motorhome. Wouldn't this be a cm2350? Or x15? RE: ISX605 high oil temp - Unilevers - 02-13-2019 i assume its a x15, and i assume it is in a motorhome/coach/diesel pusher etc. Coach's Inherently run hotter than trucks due to inadequate cooling, you cannot get around this. it will run in the higher temps of normal, but should not throw a CEL. Above 250 is hot, 255 i would be letting my foot outa it, and 260 i would have started backing out seriously. At 605/1850 in a x15 with emissions intact its going to run 240-250 under full load as your are the highest power its rated for, shitty cooling, climbing a hill, and its warm out. i would not be concerned if you could maintain 250 max under those conditions. what oil is in this thing? Are you sure its stock? have they touched it engine wise? Is the oil tstat there? is the rad/cac plugged? Where is the rad/cac on this coach mounted and is it possible to get adequate air flow? Is cummins aware that this engine at this power is even in a coach like that and say it will perform with that calibration? Is the proper programming in it and what is the ESN and calibration currently in it? Whats the filter like for differential pressure? is the tranny lugging it under load and not allowing it to be high in the rpm range easing off engine load? Does it have any external crap or resistors or trick switches on it? I have many questions, answer them if you can. Coach's have certain calibrations and could only go to lower torque values for a reason. The cooling isnt there and they get hot and cummins knows this and has specific calibrations designed for specific coach chassis. RE: ISX605 high oil temp - smitty210 - 02-14-2019 Thanks guys, I'll pass this on. This is a side mounted rad, with a variable speed hydraulic powered fan. Yes, everything is stock on this. They tell us to drive it like we stole it, because these engines don't get enough work, they sit too much. |
