CAT C15 Acert Injector Cup/Sleeve HELP - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: CAT C15 Acert Injector Cup/Sleeve HELP (/showthread.php?tid=4153) |
CAT C15 Acert Injector Cup/Sleeve HELP - revlimited - 02-14-2019 Hi I have a 2007 Freightliner Columbia with a MXS cat engine. I am replacing the injector cups/sleeves. I ordered the cups using my serial number, however the one I pulled out is a different serial number. I was given 263-4920 from the dealer, however I took out 227-4239 from my engine. When side by side I notice a millimeter of difference. On the cat website when I enter my engine serial number both cups say "Verified part-to-equipment match." What do you guys recommend? https://parts.cat.com/en/catcorp/263-4920 https://parts.cat.com/en/catcorp/227-4239 MXS83337 RE: CAT C15 Acert Injector Cup/Sleeve HELP - tree98 - 02-14-2019 Sounds like they gave you the wrong ones, probably should call and ask them. RE: CAT C15 Acert Injector Cup/Sleeve HELP - 389driver - 02-14-2019 It’s just an updated part number. RE: CAT C15 Acert Injector Cup/Sleeve HELP - Unilevers - 02-14-2019 i have verified that it is indeed a updated number RE: CAT C15 Acert Injector Cup/Sleeve HELP - revlimited - 02-14-2019 Awesome thank you so much! |
