| cm2250 egr cooler leak need advice - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: cm2250 egr cooler leak need advice (/showthread.php?tid=4171) |
cm2250 egr cooler leak need advice - Leeter - 02-18-2019 ok so im tuned and deleted. 99% sure egr cooler is leaking. since its not in use anymore what are my options? dont like the idea of buying a new one if its disabled anyway... (disabled as in egr is unplugged only) thanks! RE: cm2250 egr cooler leak need advice - Nilao - 02-18-2019 Taking it off and having plugs welded into each end?...just make sure they use high grade stainless steel at least 1/4 inch thick....might be a better way...I'm not sure RE: cm2250 egr cooler leak need advice - Rawze - 02-18-2019 Assuming you live on a country where that stuff is legal, buy a new one, or weld shut the exhaust side of it (not the coolant passages),.. do not block coolant flow through it. You could also just buy a new one and count the blessings that you have no more EGR issues (hopefully you have programming that has been verified/done by someone recommended on this forum so that your not trading dpf problems with repeating engine failure problems) ... It is rare that the OE cooler will leak (unless abused or installed incorrectly), that it is probably worth buying another just to keep the truck as stock as possible. |
