| 2006 9400i with 870 isx.. do data link in dash - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: International Trucks Related Help (/forumdisplay.php?fid=69) +--- Thread: 2006 9400i with 870 isx.. do data link in dash (/showthread.php?tid=4184) |
2006 9400i with 870 isx.. do data link in dash - wellrun - 02-20-2019 no data in dash..lights are flash gauges are pointing down gauges cycles when ignition, then after a few secs no data link RE: 2006 9400i with 870 isx.. do data link in dash - Chamberpains - 02-20-2019 Check the breakers in the glove box. Make sure none are tripped. When did the problem start? Anything special happening at that time? RE: 2006 9400i with 870 isx.. do data link in dash - wellrun - 02-20-2019 after truck was washed RE: 2006 9400i with 870 isx.. do data link in dash - Rawze - 02-20-2019 (02-20-2019 )wellrun Wrote: after truck was washed check all the cab plugs. maybe the J1708 0r J1939 connections shorted out?. RE: 2006 9400i with 870 isx.. do data link in dash - Chamberpains - 02-21-2019 When i get a chance later today, I'll see if I can dig up a copy of the schematic for the data link wires. But for now check your firewall connectors. The round 1's on the driver side (turn counter clockwise to remove) and the rectangular 1's on the passenger side (I believe its a 1\4" socket needed to remove them) also as Rawze said remove the ECM connectors and give them a check. they possibly washed dirt or water or even loosened or cut wires at those connectors with their high pressure wand. |
