| Locked out - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Locked out (/showthread.php?tid=419) |
Locked out - Coco620 - 05-12-2016 Hello guys Was getting ready to do an injector test on a truck computer was taking it's time si I walked away for a minute and I was locked out locked to read only mode...has anyone had this problem? Thanks RE: Locked out - Hedley - 05-12-2016 if you were using insite and connected under "Master" privileges and lost communication with the ECU then the program will try to re-establish the connection but may have done so under "read only" privileges, it will usually ask your permission to re-connect. RE: Locked out - Signature620 - 05-13-2016 Is the ECM password protected? RE: Locked out - Coco620 - 05-13-2016 Not sure I don't think it is cuz I've plugged into it b 4 & it's locked w/o being hooked up to anything, one of the fine gentlemen is gonna fix me up I figured I'd throw it on here to get feedback.. Thanks |
