EGR fault code - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: EGR fault code (/showthread.php?tid=4197) |
EGR fault code - alborz - 02-25-2019 This is a code I got today It feels less power when accelerating Any help will be appreciated RE: EGR fault code - tree98 - 02-25-2019 What engine 870/871/2250? How many miles? Is it still mandated ? RE: EGR fault code - alborz - 02-25-2019 (02-25-2019 )tree98 Wrote: What engine 870/871/2250? How many miles? Is it still mandated ? Mandated 920 miles 871 RE: EGR fault code - Rawze - 02-25-2019 check the egr temp sensor is not unplugged or shorted high?. I have also seen that code when the egr cooler was not doing its job properly. - Especially true of After-market egr coolers. They are notorious for not cooling the exhaust gas properly, and it can lead to a destroyed enigne. RE: EGR fault code - alborz - 02-25-2019 (02-25-2019 )Rawze Wrote: check the egr temp sensor is not unplugged or shorted high?. Thanks Rawze Sensor is good Could the egr valve stucked open? RE: EGR fault code - RTRUCKING48 - 02-26-2019 Check your Egr valve clean it RE: EGR fault code - alborz - 02-26-2019 (02-25-2019 )alborz Wrote:(02-25-2019 )Rawze Wrote: check the egr temp sensor is not unplugged or shorted high?. I took off the egr valve today These are picture of valve opening It seems exhaust gas never passed the valve but there are signs of coolant Even at the bottom of valve was some fluid And solid matter like mud or something like that RE: EGR fault code - tree98 - 02-26-2019 Doesn't look like exhaust has been going through that for quite a while. You sure this engine hasn't been demandated ? RE: EGR fault code - Rawze - 02-26-2019 looks like no egr gas has gone through that thing in a long time. Also, it is normal to have mud in it if that is the case,.. condensation (not coolant) likes to build up like mad in that circuit if it has been blocked off. |
