Anyone know a good mechanic near ennis tx? - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Anyone know a good mechanic near ennis tx? (/showthread.php?tid=4254) |
Anyone know a good mechanic near ennis tx? - mpreiss321 - 03-07-2019 2011 Int’L prostar, cm871 engine Tossed up spn 94 fmi 18 shut down my fuel pump. Can it be fixed roadside or do I need a tow truck? Looking for a good shop in the area of ennis tx. Thanks RE: Anyone know a good mechanic near ennis tx? - Chamberpains - 03-07-2019 It can possibly be troubleshot and repaired roadside. It's a low fuel pressure code. Can be anything from plugged filters to fuel pump to a faulty anti drain back valve to something as simple as a fuel tank being empty. Cummins quickserve give a detailed troubleshooting tree for spn 94 fmi 18 or cummins code 482 with no amber light and 2215 with an amber light |
