Cm870 high pressure relief valve - Printable Version
+--- Thread: Cm870 high pressure relief valve (/showthread.php?tid=4269)
Cm870 high pressure relief valve - Kevroo - 03-11-2019
When changing the high pressure relief valve that screws into fuel rail in between the metering and timing actuators, is there something inside of there I also need to change or is it a screw in valve and go?
RE: Cm870 high pressure relief valve - Rawze - 03-11-2019
register your enigne on quickserv.com - its free and you will have access to all drawings and procedures.
