|  DEF system - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: DEF system (/showthread.php?tid=4273)  |
DEF system - castillon11011 - 03-11-2019 So I’m getting a check engine light on, when I checked it code reads “ aftertreatment SCR catalyst conversion efficiency valid but below normal” it’s also telling me the Nox sensors are reading abnormal. Now I fell asleep all night with the truck idling and thought maybe I had plugged the filter so I did a forced regin and started to look at all the parameter, I found the both nox sensors were reading stable but the sensor for ammonia was reading not stable. Anyone have a clue about what can be going on here. I’m thinking maybe the def dosing valve could be plugged and not injecting enough def to cause a stable reaction but honestly I have no idea? Where’s the sensor that reads that information anyways? Any help will be appreciated  |
