| In cab scanner (not code) - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: In cab scanner (not code) (/showthread.php?tid=4286) |
In cab scanner (not code) - Rounded_nut - 03-14-2019 I'm looking for a reasonably priced small scanner for the assorted docs we work with, having a load tray would be handy, does anyone have experience either way with one to recommend? RE: In cab scanner (not code) - snailexpress - 03-14-2019 (03-14-2019 )Rounded_nut Wrote: I'm looking for a reasonably priced small scanner for the assorted docs we work with, having a load tray would be handy, does anyone have experience either way with one to recommend?I'm really satisfied with my DELL B1165 laser 3 in 1. Can connect wire or wireless. Scanner(tray or screen) Printer Fax 4 years in use. Look for something similar what can fit the place in your sleeper. |
