Cummins ISX fault # 3697 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Cummins ISX fault # 3697 (/showthread.php?tid=4335) |
Cummins ISX fault # 3697 - southernfuels - 03-24-2019 I have a fault code of 3697. I do have Cummins Insite updated. I have looked up this fault in Cummins Quick serve but have no idea of how to correct or fix this problem. I have a 2013 Pete with a Cummins ISX-15 2250. My insite is wireless to internet here in office(truck is parked 12 miles away) and I have ordered a usb modem to have the internet in the truck. All help is appreciated. RE: Cummins ISX fault # 3697 - Rawze - 03-24-2019 FAULT CODE 3697 -- Engine Control Module Calibration Memory - Bad Intelligent Device or Component -- You have a ram memory vs. flash program mis-match. This is usually an indication of a corrupt program. I.E.> Make an insite ecm image, then re-flash the ECU with a clean factory program that matches what the the ser# engine calls for on quickserv. Restore and features and parameters/insite image to restore the settings for that make/model truck. Crank it up and let the truck run for a good 10 minutes to re-build the ecu's internal ram data + re-establish cylinder balancing data, etc. before continuing on. If the fault does not go away, maybe the ecm is going bad. RE: Cummins ISX fault # 3697 - southernfuels - 03-24-2019 Thanks Rawze, Pretty sure I don't know how to do what you are suggesting so Ill start by looking for instructions on using Insite. Once I get my laptop on line in the truck I may be able to use Team viewer to get some help. Thanks Beau RE: Cummins ISX fault # 3697 - zyNoT - 09-23-2019 Did you ever figure out what it was? RE: Cummins ISX fault # 3697 - Heritage23 - 09-02-2020 This issue happens to me when I plug in my Bluetooth adapter for my eld RE: Cummins ISX fault # 3697 - Rawze - 09-03-2020 (09-02-2020 )Heritage23 Wrote: This issue happens to me when I plug in my Bluetooth adapter for my eld I've never heard of that one ... fault he has is related to a corruption of memory in the ecm. - You sure your bluetooth device does not have a virus on it that is trying to write data to the ecm? |
