Coolant filter - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Coolant filter (/showthread.php?tid=4341) |
Coolant filter - little john - 03-27-2019 Has anyone had problems with the coolant filter leaking around the seal? Mine started a leak I thightenfilter some and it leaks more after tightening. Going to install a new filter , hope it fixes leak? RE: Coolant filter - Rawze - 03-27-2019 its fairly common if the filter is not changed often enough... pull the filter off and clean the dried coolant/crud built up on the flange by gently using a flat blade screw driver. Use a scotch bright pad and get it nice and smooth/shiny again. Use grease on the gasket when installing the new one. RE: Coolant filter - little john - 03-27-2019 Thanks Rawze, I'll check it out in the morning |
