Volvo air governor location - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Volvo air governor location (/showthread.php?tid=4363) |
Volvo air governor location - ksmech11 - 03-31-2019 1999 Volvo D12. Where the heck is the air governor? Another shop replaced drier and compressor and for the life of me i cant find the governor. Wont stop building air. RE: Volvo air governor location - snailexpress - 03-31-2019 (03-31-2019 )ksmech11 Wrote: 1999 Volvo D12. Where the heck is the air governor? Another shop replaced drier and compressor and for the life of me i cant find the governor. Wont stop building air.I believe D12 governor is mounted right on the compressor. RE: Volvo air governor location - ksmech11 - 03-31-2019 I figured that as well. Not there unless the last shop omitted it! LOL RE: Volvo air governor location - Magard - 03-31-2019 Look on the fire wall where the hood makes its curve from flat to vertical. Air line for brakes and what not are right there also. It’s got a schrader valve on it on my truck. Pictures coming. Admit I can’t figure out why these pictures are always turned 90 degrees. Put your head on sideways maybe you can figure out what I’m talking about. RE: Volvo air governor location - snailexpress - 03-31-2019 This one is for Cummins engine. D12 has different compressors and governor location depends on which compressor is installed. |
