| Bendix purge valve ? - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Bendix purge valve ? (/showthread.php?tid=4446) |
Bendix purge valve ? - Geared_Cortex - 04-23-2019 Hi I drive a 2011 prostar cm-871 daycab . I was was droping a container at the port when It started that spitting air from bottom of the air dryer. It sounds like a rattle snake and it won't build up any air in the tanks but won't lose any either. It stops when I turn of the truck . I'm still there trying to fix this . Please any help would be very appreciated. Thanks in advance. RE: Bendix purge valve ? - Rawze - 04-23-2019 if it has more than a few years on it and 600+k miles, I wouls suggest you replace the whole damn unit. the aluminum housing where the valve sits wears out too. RE: Bendix purge valve ? - kmk - 04-24-2019 Possible governor, plastic check valve, or purge valve issue. RE: Bendix purge valve ? - Geared_Cortex - 04-24-2019 The truck has 400k but 14000 hours and it's up in Canada with all the salt in the winter . The valve cost 100$ and the unit about 400$. I bought the valve but my supposedly heavy duty pliers broke on me trying to remove the bad one . So I'm gonna return it and get the hole unit first thing in the morning. For 300$ more I guess it's worth not having to worry about that for awhile. Thanks guys RE: Bendix purge valve ? - dhirocz - 04-24-2019 Mine did that once. Drain all of your air tanks...including the dryer reservoir tank. Turns out mine was full of water and slurry because dryer wasnt working. I did as rawze said, and replaced my whole unit with a bendix unit to include the reservoir. Do yourself a favor and change the drain valves on all your tanks too. RE: Bendix purge valve ? - uncleal13 - 04-24-2019 I replace the entire air dryer every fall. You can get an AD-9 remanufactured one from Fort Garry or even Freightliner for under $200 exchanged with your old one. |
