Exhaust leak at dpf flex connector - Printable Version
+--- Thread: Exhaust leak at dpf flex connector (/showthread.php?tid=451)
Exhaust leak at dpf flex connector - Trkdrv in ga - 05-19-2016
How will an exhaust leak at dpf flex connector effect dpf and engine for short term. Run maybe 800 miles. This is on a 09 peterbilt 387 with isx 947xxx miles. Does anyone know?
RE: Exhaust leak at dpf flex connector - snailexpress - 05-19-2016
(05-19-2016 )Trkdrv in ga Wrote:  How will an exhaust leak at dpf flex connector effect dpf and engine for short term. Run maybe 800 miles. This is on a 09 peterbilt 387 with isx 947xxx miles. Does anyone know?
At 947xxx miles!!! Is this flex before DPF or after DPF to exhaust? If it before DPF regeneration will not go properly. For short run it OK
RE: Exhaust leak at dpf flex connector - Rawze - 05-19-2016
at 947k miles, that engine is ready for an inframe. Are you prepared for it?
RE: Exhaust leak at dpf flex connector - Trkdrv in ga - 05-20-2016
Had inframe at 750k so was told what is the on that?
RE: Exhaust leak at dpf flex connector - Rawze - 05-20-2016
(05-20-2016 )Trkdrv in ga Wrote:  e at 750k so was told what is the on that?
Did they replace the head with a new one?
BTW: Any leak in exhaust between the engine and the DOC/DPF can and will cause regen problems.
