| cm570 cam in a 2250 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: cm570 cam in a 2250 (/showthread.php?tid=4539) |
cm570 cam in a 2250 - Vurtle - 05-16-2019 Will a cm570 camshaft in a demandated 2250 with a fixed turbo restore jakes? I believe it will, but checking to see others opinions. RE: cm570 cam in a 2250 - Lonestar10 - 05-16-2019 Fixed turbo = no 3rd stage Jake for starters. And how does a different cam fix stage 1-2? If your current cam is good then only thing that will fix Jake's is electrical. RE: cm570 cam in a 2250 - Vurtle - 05-16-2019 cm570 should have different jake cam lobes is my thought. I have a few 2250 cams laying around, but no 570 cam laying around to compare it to. RE: cm570 cam in a 2250 - Rawze - 05-16-2019 (05-16-2019 )Vurtle Wrote: Will a cm570 camshaft in a demandated 2250 with a fixed turbo restore jakes? I believe it will, but checking to see others opinions. HOW ABOUT PUTTING THAT ENGINE BACK THE WAY IT IS SUPPOSED TO BE AND NOT BUTCHERING IT INTO A COMPLETE PIECE OF GARBAGE !!!!! PUT THE VG TURBO BACK ON IT --- PUT A PROGRAM IN IT THAT WILL RUN THE ENGINE AND ITS VG PROPERLY --- END OF STORY!!! I DO NOT TOLERATE THIS TYPE OF MORON-DRIVEN HACK-JOB BUTCHER CRAP NON-VG MODS AND GARBAGE TUNING REDNECK HACK-FU#CKERY ON MY FORUM!!! --PERIOD!!!. - TAKE THAT S#IT TO OTHER FORUMS WHERE PEOPLE LIKE TO DESTROY THEIR ENGINES AND THEIR TRUCKING BUSINESS WITH SUCH TOTAL BULLS#IT!!! {this is your one and only warning that I will not tolerate such garbage on my forum!} |
