Freightliner Transmission Repair - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Freightliner Transmission Repair (/showthread.php?tid=4618) |
Freightliner Transmission Repair - realbad993 - 05-31-2019 Recently changed transmission from an Eaton lighting FRLO to standard FRO 10 speed. Now our ELD connects to our phone but will not automatically change to show driving after reaching 5 mph. We need to do it annually and don't know why. FTL dealer checked pins at diagnostic connector, voltage in and ground and said all ok. Speedo & odometer read correctly. Tried spare ELD, same results. Any ideas? RE: Freightliner Transmission Repair - Lonestar10 - 05-31-2019 So you can move in the truck stop parking lot without tripping the damn thing I call that a win RE: Freightliner Transmission Repair - Nilao - 05-31-2019 Issue is that December 31 it updates and you can no longer manually go to the drive line...not sure of it matters but did you change the transmission in the ECM to reflect the change? There has to be a commumication error between the trans and ecm or the ECM and body controller. The lightning was an autoshift if I remember correctly...the addressing to the body controller is probably wrong...something simple to fix i am sure. RE: Freightliner Transmission Repair - Lonestar10 - 06-01-2019 guess i didnt know that part about no more manual. is it going to auto take you out under 5mph if not its a damn joke. RE: Freightliner Transmission Repair - Nilao - 06-02-2019 My understanding is it is going to be 5 mph or 200 ft. Isn't going to all for idling through the parking lot anymore. RE: Freightliner Transmission Repair - Lonestar10 - 06-02-2019 guess ill have to set gps settings on tablet to low and put a switch on vss for idling upto the pumps. i have no problem with this elog stuff but not being able to stay outa drive without kicking it into drive to make a quick move is downright dumb. |
