Belt Tensioner - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Belt Tensioner (/showthread.php?tid=4632) |
Belt Tensioner - Mike21625 - 06-04-2019 On two of my 2350s , the threads in the bracket that holds the air conditioning Belt tensioner wants to strip out. What is a fix?Drill it out and put a longer bolt in with a lock nut. RE: Belt Tensioner - Nilao - 06-04-2019 Drill it out and put in helicoils is an option also. Just don't go too deep. RE: Belt Tensioner - smorgan87 - 06-04-2019 Drill it and cut new threads RE: Belt Tensioner - Rawze - 06-04-2019 (06-04-2019 )Mike21625 Wrote: On two of my 2350s , the threads in the bracket that holds the air conditioning Belt tensioner wants to strip out. What is a fix?Drill it out and put a longer bolt in with a lock nut. heli-coil them. - always use a torque wrench w/proper torque setting and they won't strip out. RE: Belt Tensioner - Mike21625 - 06-04-2019 Ok ,Thanks, We fixed them today. Found a company that has the same type of bolt only a 1 inch longer. Put the bolt in and put a flat washer,lock washer and nut on the backside. Seems to work fine. RE: Belt Tensioner - Rawze - 06-05-2019 (06-04-2019 )Mike21625 Wrote: Ok ,Thanks, We fixed them today. Found a company that has the same type of bolt only a 1 inch longer. Put the bolt in and put a flat washer,lock washer and nut on the backside. Seems to work fine. Hopefully it will not let go. If it does, it could take out the fan, radiator, and a lot of other damage. |
