R134a pressure question - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Pete & KW related Help... (/forumdisplay.php?fid=70) +--- Thread: R134a pressure question (/showthread.php?tid=4658) Pages: 1 2 |
RE: R134a pressure question - Wiseman - 06-10-2019 Not many people pay close attention to the air gaps within and in between condenser, CAC , radiator and shroud. Air is taking the easiest/less resistant path to engine fan blades. On top off that some condensers are pathetically inefficient and need increased amount of air flow just to make some heat exchange . In cases like this , the shop fan will make noticeable difference in performance and readings . I’m sure if you improve the air flow thru condenser you’ll see much better results. |
