Cat C15 Acert oil pressure issue - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: CAT, Detroit, and Other engine related Help... (/forumdisplay.php?fid=72) +--- Thread: Cat C15 Acert oil pressure issue (/showthread.php?tid=4684) |
Cat C15 Acert oil pressure issue - Jose9640 - 06-17-2019 Driver said oil pressure while driving went straight to 0 and had no throttle response. As he put it in neutral, oil pressure went back up to normal. He said that happened to him twice today on a 500 miles run today. I checked the codes with Cat ET and there 285-7 and 385-1 code. 385-1 low intake valve actuation system oil pressure 285-7 intake valve actuator #1 not responding. My concern is why would the oil pressure gauge go straight to 0 and come back if the problem seems to be in the intake valve actuators/housings? RE: Cat C15 Acert oil pressure issue - Lonestar10 - 06-17-2019 sounds like electrical issues giving the computer a a heart attack for a second. RE: Cat C15 Acert oil pressure issue - Waterloo - 06-18-2019 Have seen the ISX do that and it was the sending unit going bad. Or, you could have a short in the wiring, that is where I would start, wiring and then oil pressure sending unit. No clue on the codes. |
