Cm875ism hard start after long park - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Cm875ism hard start after long park (/showthread.php?tid=4693) |
Cm875ism hard start after long park - wellrun - 06-20-2019 Cummins ism cm875..CRANK BUT NO START after a long park...overnight or more...it starts easily with a little spray of bagon and will take long to start if not shutdown for hours.... change fuel lines etc RE: Cm875ism hard start after long park - Lonestar10 - 06-20-2019 starter cranking at correct speed? low compression? or fuel system loosing prime. RE: Cm875ism hard start after long park - wellrun - 06-20-2019 Cranking speed seems fine... builds up oil pressure RE: Cm875ism hard start after long park - Lonestar10 - 06-20-2019 oil pressure means nothing if it has poor compression and the ether helps it spin a bit faster to take off. RE: Cm875ism hard start after long park - Chamberpains - 06-21-2019 Sounds like your fuel system is losing its prime. There is probably an anti drainback valve or check valve somewhere that isn't working properly. I don't know anything about the cm875. Have you gotten on to https://quickserve.cummins.com/info/index.html and registered your engine? Its free. It has all kinds of helpful info directly from the manufacturer of the engine. RE: Cm875ism hard start after long park - Moose - 06-21-2019 Could be losing prime, could also be a weak solenoid, weak CELECT pump or sticking shutoff valve. you need to mechanically monitor your rail pressure during cranking and while running. Will it act the same on the tank plumbing as running it out of a bucket? |
