| Truck keeps dying - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Truck keeps dying (/showthread.php?tid=4724) |
Truck keeps dying - sstrong1 - 06-27-2019 My truck dies after a day or two of sitting. Is it bad batteries or a connection. What’s the best way to find out RE: Truck keeps dying - tree98 - 06-27-2019 Not even close to enough information. What make/ model truck, what engine, miles, etc. Was any work recently done to the truck? When it dies does it start again right away? If not What do you have to do to get it started? RE: Truck keeps dying - Lonestar10 - 06-27-2019 Does it have a fridge? are you leaving it on? most OEM fridges will kill truck batteries over the weekend. anything else plugged into truck when its not being driven that can be drawing power? most newer trucks have "load shedding" and it turns off most but not all of the plug ins and things that draw power to protect the batteries. RE: Truck keeps dying - sstrong1 - 06-28-2019 Volvo vnl 670. It may be the inverter but I turn it off. That’s the only thing plugged up. I do see some corrosion on the battery wiring that maybe a factor also. RE: Truck keeps dying - smorgan87 - 06-28-2019 When u say it dies. Do u mean the engine dies after idling a cpl days or the batteries are dead after sitting over the weekend? If batteries, inverters will kill them over a few days if not disconnected RE: Truck keeps dying - Mr Hagg - 06-28-2019 I find the best way to find a drain on a truck is with a thermal camera .. I look for hot spots. If you dont have access to that. Take off negative cable and I use a volt meter and put it inline from neg bat to neg cable. Then start unplugging stuff until it goes to nothing. With a good draw it will show 12v once its gets down to like 4 or so then that may be your truck normal... Check alternator as those tend to have regulators stick and cause it. You will know cause alternator will be warm after setting over night. RE: Truck keeps dying - Rawze - 06-28-2019 (06-28-2019 )Mr Hagg Wrote: I find the best way to find a drain on a truck is with a thermal camera .. I look for hot spots. If you dont have access to that. Take off negative cable and I use a volt meter and put it inline from neg bat to neg cable. Then start unplugging stuff until it goes to nothing. With a good draw it will show 12v once its gets down to like 4 or so then that may be your truck normal... Check alternator as those tend to have regulators stick and cause it. You will know cause alternator will be warm after setting over night. very well said. here is also some fine examples... http://rawze.com/forums/showthread.php?tid=1393&pid=11663#pid11663 |
