| ISX Rocker Shafts - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: ISX Rocker Shafts (/showthread.php?tid=4752) |
ISX Rocker Shafts - multitask - 07-04-2019 Gents, Might be pulling the valve cover off this weekend and doing another overhead adjustment/checking cam etc. I would like to know what signs show worn rocker shafts without pulling the entire assembly off? Both trucks running well no leaky injectors, don’t burn oil or lose coolant, visually no blow by either only thing that bothers me is abit of a squeaky/ticking sound that can be heard once the compressor stops running. Do all CM871 sound like that? Both of them do it! Sounds like it’s coming from the actuators, did pull one of the fuel ones apart when I was doing the leak down test and it looked clean, otherwise been happy with how they are running. Cheerssss RE: ISX Rocker Shafts - Chamberpains - 07-04-2019 Generally the rocker shafts themselves won't be worn. The rollers going to the cams will be what shows signs of scarring, pitting, scrapes and scores. Looking like this. [attachment=5188] [attachment=5189] And the roller will show the same type of wear. [attachment=5190] Just give all components a thorough look over while your barring the engine over for each adjustment. But really, if you're thinking other parts may be shot, why not just unbolt the rocker set and check it out? Your already adjusting the valves. All you need to do is unbolt them. Then torque them back down after inspection. RE: ISX Rocker Shafts - Signature620 - 07-04-2019 The main sign of worn rocker shafts is a rattle/slapping sound in the overhead after the engine brakes are turned off. When the cover is off, rotate the engine brake levers back and forth to make sure they locate firmly in their neutral position - If they don't, then the weren't pocket in the shaft will probably be elongated. RE: ISX Rocker Shafts - multitask - 07-04-2019 Thanks for the info guys RE: ISX Rocker Shafts - Hammerhead - 07-04-2019 (07-04-2019 )Signature620 Wrote: The main sign of worn rocker shafts is a rattle/slapping sound in the overhead after the engine brakes are turned off. When the cover is off, rotate the engine brake levers back and forth to make sure they locate firmly in their neutral position - If they don't, then the weren't pocket in the shaft will probably be elongated. If the jake rockers don’t snap into their resting position as Signature620 stated, then the shafts need to be replaced, however DON’T just change the shafts, also change the check valves and springs in the jake rockers, as the valves will be worn round instead of tapered and the springs are small and weaken over time. |
