| fault code help - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: fault code help (/showthread.php?tid=4757) |
fault code help - alborz - 07-06-2019 Anybody can explain this? I just can say sometime in the dash a warning sign appears saying " high Curren draw from batteries, check your charging system" everything is good. batteries, alternator [attachment=5193]. also I have this code but couldn't find anything on Quick serve. [attachment=5194] RE: fault code help - Waterloo - 07-06-2019 What is the volt meter on the dash showing you? I'm suspecting the alternator is failing. When my alternator failed, I was having current spikes. I forget what code popped up, but I was on my way to the TA when all of this suddenly happened. I took it in and we swapped out the alternator, along with finding ALL of my cables and grounds were shot. I took the truck home and spent a few days yanking cables from the battery box and replacing over 100 feet of 0 AWG cable and an assortment of grounds. It came from the factory like this, exposed copper everywhere. Or, you have one heck of a parasitic draw, Mr Hagg posted a reply the other day on how he tests for this. http://rawze.com/forums/showthread.php?tid=4724 I hope this helps, but I am not a mechanic, just going from experience. |
