DOC/DPF Fitler cleaning - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: DOC/DPF Fitler cleaning (/showthread.php?tid=4829) |
DOC/DPF Fitler cleaning - Mavrix - 07-20-2019 I am wanting to take my DOC/DPF filters in for cleaning (I have never done it in the two years I have owned the truck with 623k plus I just did EGR turn-up and EGR cleaning) and I cannot remember if I need to have the insite program to tell the cpu that the filters have been cleaned or not. I remember either reading and/or watching one of Rawze's video's saying as such but I cannot find it anywhere. So if someone can let me know before I do it that I need to get the insite program and equipment before I drop my filters it would be many thanks. RE: DOC/DPF Fitler cleaning - Rawze - 07-20-2019 If you pull the cans nad have them cleaned, baked, and de-ashed, then yes,... you need insite to tell the engine computer that you have replaced/serviced them (performing a 'dpf replecement' in insite I think). Otherwise the 'tampering' logic has a high chance of setting itself on and say the things are missing. |
