| @m*m^2 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: @m*m^2 (/showthread.php?tid=4849) |
@m*m^2 - david24 - 07-24-2019 What does @m*m^2 mean when talking about tuning? Just ran across it and didn't know what it was referring to RE: @m*m^2 - Lonestar10 - 07-24-2019 its a custom tune from one of our reputable sources on this forum RE: @m*m^2 - Chamberpains - 07-24-2019 I heard a wizard concocted it and then claims its not witchcraft. RE: @m*m^2 - hhow55 - 07-24-2019 Concocted by the wizard of rawze!!![attachment=5240] RE: @m*m^2 - david24 - 07-24-2019 (07-24-2019 )Lonestar10 Wrote: its a custom tune from one of our reputable sources on this forumWho is that reputable source? I need to contact that person RE: @m*m^2 - Waterloo - 07-24-2019 You are already there, he may respond if you are lucky. Been running it for a few years. Only works on the CM-871 motor. RE: @m*m^2 - david24 - 07-25-2019 (07-24-2019 )Waterloo Wrote: You are already there, he may respond if you are lucky. Been running it for a few years. Only works on the CM-871 motor.Well then I'm out because I have the cm2350 RE: @m*m^2 - MageRoyal - 07-25-2019 (07-25-2019 )david24 Wrote:(07-24-2019 )Waterloo Wrote: You are already there, he may respond if you are lucky. Been running it for a few years. Only works on the CM-871 motor.Well then I'm out because I have the cm2350 it exists for 2350. maybe pm Mommaburt, Unilevers, Mr. hag, rawze, gearhead. |
