Got lucky - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Your Daily Blog (/forumdisplay.php?fid=77) +--- Thread: Got lucky (/showthread.php?tid=4911) |
Got lucky - Lonestar10 - 08-07-2019 Sitting in my truck in the AC I see a waft of blue smoke then smell burning grease so I pop the hood open just in time to hear a clunk and Sparks fly out from under the fan pulley. So threw the hood shut incase it came apart as I was going for the key luckily it did not. Now sitting at shop as I couldn't find an assembly or rebuild kit myself in Minneapolis. Only thing found was a 2 speed assembly at fleetpride. Anyone use a 2speed are they still air lockup with the Eddy current running the low speed? RE: Got lucky - Unilevers - 08-07-2019 most are air lockup and magnetic 50% when freewheeling for the 2nd speed. I personally would avoid a 2 speed if i could. you mean you cant find a drivemaster super kit? those things are common as hell, is it a weird funny application? RE: Got lucky - Lonestar10 - 08-07-2019 Says 9908503 Horton RE: Got lucky - Lonestar10 - 08-07-2019 And just found out fan hub that bolts to engine is damaged now gota find that. Thing wasn't giving me a lick of trouble till today. Of course there isn't one in all of Minnesota gota get it out of Chicago. RE: Got lucky - Lonestar10 - 08-07-2019 At least my insurance is good only had to pay 250 of the 700 tow bil they cover up to 5000 for towing to shop of my choice plus I get 100 a night for lodging and if I wanted to I get 200 a day for truck rental up to 1000 in a week for that 250 dollar deductable RE: Got lucky - Pd6cas2 - 08-08-2019 Blaine Brothers In Blaine, Mn is a good shop’talk to Henry in parts Department. 763-780-5130 RE: Got lucky - Lonestar10 - 08-09-2019 Yeah I would have been there for 2 days as I called there and they said they couldn't get me till third shift which means they wouldn't have been able to order the hub out of Chicago as early as Mike's truck and trailer did. I didn't do too bad I skated out of there at $1,100 in parts and $350 in labor RE: Got lucky - Pd6cas2 - 08-09-2019 (08-09-2019 )Lonestar10 Wrote: Yeah I would have been there for 2 days as I called there and they said they couldn't get me till third shift which means they wouldn't have been able to order the hub out of Chicago as early as Mike's truck and trailer did. I didn't do too bad I skated out of there at $1,100 in parts and $350 in labor 10/4 |
