| Mechanic MS - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Mechanic MS (/showthread.php?tid=4996) |
Mechanic MS - Z7Mike - 08-26-2019 Looking for recommendations on a mechanic in the Laurel, MS area off of I-59. 2014 Peterbilt with ISX. Smelt burning clutch, fan isn’t running at speed like it should and a/c started blowing hot. Coolant and oil temps good at highway speed but get warm, 210 or so, once parked. Not sure if clutch went out on fan or high pressure switch went out. Any recommendations on a mechanic between Laurel, MS and Houston, TX? Thanks RE: Mechanic MS - david24 - 08-26-2019 (08-26-2019 )Z7Mike Wrote: Looking for recommendations on a mechanic in the Laurel, MS area off of I-59. 2014 Peterbilt with ISX. Smelt burning clutch, fan isn’t running at speed like it should and a/c started blowing hot. Coolant and oil temps good at highway speed but get warm, 210 or so, once parked. Not sure if clutch went out on fan or high pressure switch went out. Any recommendations on a mechanic between Laurel, MS and Houston, TX?I stay 20 minutes from laurel. Try Burroughs Diesel RE: Mechanic MS - Z7Mike - 08-26-2019 (08-26-2019 )david24 Wrote:(08-26-2019 )Z7Mike Wrote: Looking for recommendations on a mechanic in the Laurel, MS area off of I-59. 2014 Peterbilt with ISX. Smelt burning clutch, fan isn’t running at speed like it should and a/c started blowing hot. Coolant and oil temps good at highway speed but get warm, 210 or so, once parked. Not sure if clutch went out on fan or high pressure switch went out. Any recommendations on a mechanic between Laurel, MS and Houston, TX?I stay 20 minutes from laurel. Try Burroughs Diesel I’ll call them first thing in morning. Thanks RE: Mechanic MS - david24 - 08-26-2019 (08-26-2019 )Z7Mike Wrote:(08-26-2019 )david24 Wrote:(08-26-2019 )Z7Mike Wrote: Looking for recommendations on a mechanic in the Laurel, MS area off of I-59. 2014 Peterbilt with ISX. Smelt burning clutch, fan isn’t running at speed like it should and a/c started blowing hot. Coolant and oil temps good at highway speed but get warm, 210 or so, once parked. Not sure if clutch went out on fan or high pressure switch went out. Any recommendations on a mechanic between Laurel, MS and Houston, TX?I stay 20 minutes from laurel. Try Burroughs Diesel No problem |
