| Ordering Inline 6 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Ordering Inline 6 (/showthread.php?tid=5012) |
Ordering Inline 6 - Skman - 08-29-2019 Just wondering if someone could double check my link to make sure I'm getting the right one before I click buy? https://www.ebay.ca/itm/INLINE-6-Truck-Data-Link-Adapter-OBD2-Cummins-Heavy-Duty-Diagnostic-Scanner-Tool-/133068523982?_trksid=p2385738.m4383.l4275.c10 waterloo sent me an eBay link awhile ago but that link is dead now. I don't need anything to write to the ECM. Mostly just checking codes and trouble shooting problems that I can hopefully fix myself. I have a 2013 Kenworth ISX 15 2250 Thanks! RE: Ordering Inline 6 - Soulreaver0102 - 08-29-2019 Yup. What windows you going to be running? I had issues with windows 10 and the generic adapter. Even said on website windows 7 or lower. Although I missed that until I was trying to use it. Ended up just getting a nexiq myself. Someone with more experience with that adapter could tell you for sure if it’ll work with windows 8 or higher. RE: Ordering Inline 6 - Vlad - 08-29-2019 Inline 5+ windows 7 = love :) RE: Ordering Inline 6 - Rawze - 08-29-2019 (08-29-2019 )Vlad Wrote: Inline 5+ windows 7 = love :) Amen to that!. RE: Ordering Inline 6 - Skman - 08-30-2019 (08-29-2019 )Soulreaver0102 Wrote: Yup. What windows you going to be running? I had issues with windows 10 and the generic adapter. Even said on website windows 7 or lower. Although I missed that until I was trying to use it. Ended up just getting a nexiq myself. Someone with more experience with that adapter could tell you for sure if it’ll work with windows 8 or higher. Thanks for the heads up. I've got two laptops....an older one with Vista and the other with windows 7 so one of them should work |
