| 14 liter Detroit - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: 14 liter Detroit (/showthread.php?tid=5013) |
14 liter Detroit - Speedy - 08-29-2019 I have a 14 liter Detroit pushing water out of the radiator tank can someone tell me the issue it has been modified RE: 14 liter Detroit - Waterloo - 08-29-2019 Blown head gasket? And by modified, deleted? If so, when and by who? What year truck/motor/brand... Do you have pyro and turbo boost gauges? Any over heating or codes? Need more info. RE: 14 liter Detroit - Soulreaver0102 - 08-29-2019 You can get a block tester with the correct fluid from Napa to check the head gasket. RE: 14 liter Detroit - Rawze - 08-29-2019 (08-29-2019 )Speedy Wrote: I have a 14 liter Detroit pushing water out of the radiator tank can someone tell me the issue it has been modified blown head gasket is the most common scenario when you have a typical hack-job, take-your-money-and run delete. Get with Unilevers, or mommaburt (possibly gearhead) to have the program straightened out if one of those guys was not the one who did it. |
