| ISX 2014 in a Freightliner - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: ISX 2014 in a Freightliner (/showthread.php?tid=5097) |
ISX 2014 in a Freightliner - madtruckeroutlaw - 09-22-2019 GM, I have a 2014 Cascadia with a ISX in it. The other day truck regened heard a weird noise under the valve cover injector side, pulled cover couldn’t see anything, went 2 a dealer across the street(didn’t tell them I pulled the cover) they said a flatten rocker or something. I said thanks and picked up my load haven’t heard it since. Truck runs good, oils good, coolants good. As of 1100 miles still haven’t heard the noise again?? Should I find someone and do some test or not sure what to look for. Thanks Paul RE: ISX 2014 in a Freightliner - Waterloo - 09-22-2019 First thing you need to do is an overhead. You suck a valve and it is all over. RE: ISX 2014 in a Freightliner - madtruckeroutlaw - 09-22-2019 Thanks I’ll take Er in Monday!! Paul |
