| DPF / ISX Problem TRUCK 1 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: DPF / ISX Problem TRUCK 1 (/showthread.php?tid=5104) |
DPF / ISX Problem TRUCK 1 - Smooth - 09-23-2019 Alright guys needing some help on two diff trucks international is useless when it comes to helping as we know 2010 Lonestar - 485 ISX - After sinking a ton in this thing to get it on the road has been one headache after another. Latest I cannot get past Amber Engine Light comes on and shuts down. Has Black Smoke. Filter and Doc was baked 30K ago or less When it did this a couple weeks ago The only code had was for DPF Temp Sensor replaced did a forced regen. Has went 2 weeks now has the same issue again. RE: DPF / ISX Problem TRUCK 1 - hhow55 - 09-23-2019 http://rawze.com/forums/showthread.php?tid=7 RE: DPF / ISX Problem TRUCK 1 - Unilevers - 09-23-2019 2 weeks is about the time it takes to plug it up again. Any codes? regen history? etc? |
