9007 LED bulbs - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Pete & KW related Help... (/forumdisplay.php?fid=70) +--- Thread: 9007 LED bulbs (/showthread.php?tid=5138) |
9007 LED bulbs - hookliftpete - 10-02-2019 Had been running what seemed like a nice set of 9007 LED bulbs in my headlights (pete 335) however the pigtail into the one detached from the bulb inside the heat sink, unit is sealed... Running some standard halogens now. Any suggestions on better LED 9007 units? Thanks! RE: 9007 LED bulbs - Lonestar10 - 10-02-2019 Don't know good brands but just make sure DOT approved or you can be ticketed. Both headlight housings and bulbs are dot controlled in trucks and 4 wheelers to control glare and beam patterns that effect other drivers |
