| Isx15 cm2250 regen needed - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Isx15 cm2250 regen needed (/showthread.php?tid=5162) |
Isx15 cm2250 regen needed - AndriiS - 10-10-2019 [attachment=5538]Hello! I got park regeneration lamp and a lot of check engine lights. I started do regeneration but truck after 1:45 hours can’t regenerate. I don’t know what to do, a lot of faults there RE: Isx15 cm2250 regen needed - Rawze - 10-10-2019 it called an EGR tune-up... replace the IMAP sensor, clean the Delta-P sensor on the engine and its feed-pipe. Clean out all the rest of the egr piping and components. Replace the exhaust and egr back-pressure sensors, check for any CAC or other intake air leaks, ensure your air filter is new, ensure there are no exhaust leaks, clean the doser injector behind the turbo, inspect and clean the Delta-P and crossover lines for the DPF can. If it takes more then 40 minutes to regen after all that, pull the DOC and DPF cans off and take them to stealersh$it and have them baked, de-ashed, and flow-tested. - Take pics of their faces and post them here before cleaning them for some opinions. Inspect the face of the SCR element and DEF doser. Check decomp tube for buildup, and replace the DEF screen filter while your at it. and by the way .. STOP turning off the switch in the dash that cancels/prevents regens!. RE: Isx15 cm2250 regen needed - Waterloo - 10-10-2019 She is carbon packed... Stop Turning OFF the REGEN, LOL! |
