Mirror shake - Printable Version
+--- Thread: Mirror shake (/showthread.php?tid=5232)
Mirror shake - Lonestar10 - 10-29-2019
My arms going out to my mirrors have begun to wobble some cant seem to find any articles about fixing them correctly. Any replaceable bushings to replace to fix them? Same mirror setup as a ProStar
RE: Mirror shake - Brock - 10-29-2019
On my Prostar the top arm was loose/worn where it slides into the mirror assembly. I slide it out and jammed a piece of a zip tie in while I put the arm back in place, kind of shimmied it. It was solid for a year or so after that, I ended up epoxying them together down the road.
RE: Mirror shake - Rawze - 10-29-2019
a simple hose clamp at the top slip joint works just fine too. Mine have had a hose clamp on them for years.
RE: Mirror shake - shoe128 - 10-29-2019
(10-29-2019 )Brock Wrote:  On my Prostar the top arm was loose/worn where it slides into the mirror assembly. I slide it out and jammed a piece of a zip tie in while I put the arm back in place, kind of shimmied it. It was solid for a year or so after that, I ended up epoxying them together down the road.
That's what I have planned for mine as they are starting to get a littleshake a Little.
EPOXY bungies DuckTales. Yum-yum so goood
RE: Mirror shake - Semperfiservices - 02-12-2020
I got tired of janky looking zip ties, so I drilled a small hole through the top of the plastic pieces, and installed a small screw. Invisible repair, and now I can actually see behind me lol!
RE: Mirror shake - Waterloo - 02-12-2020
Gorilla tape on mine, lol.
RE: Mirror shake - JimT - 02-13-2020
(02-12-2020 )Waterloo Wrote:  Gorilla tape on mine, lol.
Gorilla tape does everything. Even patches holes in my tarps.
RE: Mirror shake - 74bassman - 07-20-2020
Replacing my front shocks, and cab air bags fixed mine.
