Eaton/fuller range selector - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Eaton/fuller range selector (/showthread.php?tid=5239) |
Eaton/fuller range selector - Daytripper - 10-30-2019 Changing the range selector on my transmission(10spd) has red line, black line and a yellow line that wasn't hooked up....anyone know what it is for and should it be hooked up to something? Guy I bought this truck from liked to cut corners. RE: Eaton/fuller range selector - marek4792 - 10-30-2019 Yellow should be just a vent line RE: Eaton/fuller range selector - Daytripper - 10-31-2019 Ok...thanks. |
