Cm2250 Fuel pump - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Cm2250 Fuel pump (/showthread.php?tid=5243) |
Cm2250 Fuel pump - Redace - 10-31-2019 Any input in where I could find a fuel pump new or reman? Cummins isx15 450 cm2250. I have the old 3 plunger pump and its leaking kenworth quoted me $3,474 for the new 2 plunger pump. Thanks RE: Cm2250 Fuel pump - smorgan87 - 10-31-2019 I thought cummins had a recall on the 3 plunger pumps to replace them. RE: Cm2250 Fuel pump - Soulreaver0102 - 10-31-2019 That’s better than what my quote was for a reman pump. Lol. $3715.19 was my quote RE: Cm2250 Fuel pump - Redace - 10-31-2019 It was $3,747 got the numbers mixed up. I was looking into the recall I think they said it was too late I have a 2013 kwt660 with 587k on it. I guess that's the best deal I'm gonna get on it RE: Cm2250 Fuel pump - Mr Hagg - 10-31-2019 You will also need the kit to do the 3 to 2 conversion on it as well.. RE: Cm2250 Fuel pump - JMBT - 10-31-2019 That sounds pretty good, I did mine a few years ago and was $4600 in with a new pump, two new fuel lines and some sealing washers and such. I was too late for the recall then on my 2012, 2250. |
