Ideas truck shutdown - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Ideas truck shutdown (/showthread.php?tid=5251) |
Ideas truck shutdown - Lonestar10 - 11-01-2019 My dad was heading home and truck just died. Has 12v at shutoff solenoid filters are good has 50-60 psi cranking on onsite 10-15psi when electric is running. Had codes for cylinder imbalance, and low fuel pressure moderately low. And I believe 1943 unknown code. 2007 t600 cm870 RE: Ideas truck shutdown - tree98 - 11-01-2019 Did you spin the filter off? Was it full of fuel? If not, maybe sucking air? fuel(gear pump) bad? I think that cylinder imbalance is pretty common on a demandated 870 RE: Ideas truck shutdown - Chamberpains - 11-01-2019 Fuel pressure is low while cranking. I think you need closer to 100 psi minimum to start. RE: Ideas truck shutdown - Chamberpains - 11-01-2019 Cylinder imbalance is very come. I get it at every filter change and random times. Its really nothing to worry about unless its really rough running. RE: Ideas truck shutdown - Lonestar10 - 11-01-2019 She spins over fast filters are full. I'm thinking gear pump also. But it's a stocker 870 no demandate RE: Ideas truck shutdown - Lonestar10 - 11-01-2019 She also has 1.4mil on pump so it's time most likely RE: Ideas truck shutdown - hhow55 - 11-01-2019 http://www.diesel-service-parts.com/cummins-isx-codes.html This should help RE: Ideas truck shutdown - Lonestar10 - 11-01-2019 Were gona go in tomorrow stop and cummins grab a new HP pump and toss it on. RE: Ideas truck shutdown - Lonestar10 - 11-02-2019 Welp Cummins was closed Pete/Ken/int/freight all didn't have a pump in stock thankfully the cm870 ifsm I put on my truck had a pump on it that I had taken off but had left at the mechanics shop we called them got the codes for door and alarm system lol went in grabbed the pump and put it on and she's back up and running. |
