Rear structure leak - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Rear structure leak (/showthread.php?tid=5259) |
Rear structure leak - earnies2 - 11-03-2019 2009 ISX rear structure leak what needs to be done and what should it cost, International prostar ISX 13 speed RE: Rear structure leak - tree98 - 11-03-2019 http://rawze.com/forums/archive/index.php?thread-4704.html RE: Rear structure leak - Waterloo - 11-03-2019 My buddy had his clutch replaced and they did not do the rear structure, in a few days it was leaking. In the end it cost him around $4000. The rear structure gasket cost him $2400 to replace. If the structure is leaking, replace the clutch. I put a soft pedal in, I think that is what it is called, in my ProStar, quite a few of us use it here. And also have the input shaft etc., replaced. RE: Rear structure leak - tree98 - 11-03-2019 I think you mean easy pedal there waterloo RE: Rear structure leak - Magard - 11-03-2019 (11-03-2019 )Waterloo Wrote: My buddy had his clutch replaced and they did not do the rear structure, in a few days it was leaking. In the end it cost him around $4000. The rear structure gasket cost him $2400 to replace. If the structure is leaking, replace the clutch. I put a soft pedal in, I think that is what it is called, in my ProStar, quite a few of us use it here. And also have the input shaft etc., replaced.2050 Easy Peddle. RE: Rear structure leak - Waterloo - 11-03-2019 Yep, Easy Pedal... Nice clutch. Never can remember what that clutch is called... LOL! Must be the once blond hair, which is now gray, and not helping matters... ;-) |
