ISX CM 871 - Printable Version
+--- Thread: ISX CM 871 (/showthread.php?tid=5322)
ISX CM 871 - skunky - 11-14-2019
is the cm871 a hard starter, below 32 degrees it will not start unless plugged in, seems to barely roll over on the warm days, have new batteries in it, is there a heavy duty starter for colder weather?
RE: ISX CM 871 - Waterloo - 11-14-2019
How old is the starter? Mine fired right up, 20* out here... I picked up a Mitsubishi HP starter up at FleetPride, good price and has been fine for the past 5 or so years.
RE: ISX CM 871 - smorgan87 - 11-14-2019
Snds like a bad starter to me.
RE: ISX CM 871 - hhow55 - 11-14-2019
Battery cable's could be corroded
RE: ISX CM 871 - skunky - 11-15-2019
ok thanks
