Cat Idle Shutdown Timer - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: CAT, Detroit, and Other engine related Help... (/forumdisplay.php?fid=72) +--- Thread: Cat Idle Shutdown Timer (/showthread.php?tid=5410) |
Cat Idle Shutdown Timer - Golfnut - 12-05-2019 I have a neighbor with a 2009 T800 with a C13. It has an Idle Shutdown timer that shuts the truck off after 5 minutes of idling unless he taps the brake or clutch. He claims he's had three dealerships try to disable it but the best they can do is change it to 5 minutes and supposedly it won't accept "0" because it its emissions setup. Any suggestions? I have CAT ET on my laptop and was going to poke around. RE: Cat Idle Shutdown Timer - tomcat - 12-05-2019 Can't really remember but i think its the way the emissions is certified. Different certifications may allow for it to be zero. RE: Cat Idle Shutdown Timer - Unilevers - 12-05-2019 its easily doable if you know how RE: Cat Idle Shutdown Timer - Golfnut - 12-05-2019 Unilevers, is it something you could walk me through or something you could do remotely if I had the truck in my shop.....(farm shop, not truck shop) |
