| black smoking cm870 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: black smoking cm870 (/showthread.php?tid=5637) |
black smoking cm870 - wellrun - 12-31-2019 hey guys ive had issues with a cm870 the was deleted and had the vgt jammed..after doing an overhual i am now noticing a thick heavy black smoke when accelerating and a lil loss of power...tried different tunes and same issue...could it be my overheads not right or turbo? RE: black smoking cm870 - tree98 - 12-31-2019 What do you mean when you say you "tried different tunes"? There are parameters that must be live edited on an 870. You can't just use an overlay that some dumbass gives you. When you say " had the VGT jammed" I really hope you didn't do this intentionally? RE: black smoking cm870 - Lonestar10 - 12-31-2019 if the engine wasnt tuned here its most likely the tune. but could be EGR if not plugged has opened, if still has VGT but its held full open then well the thing will run like garbage, the 870 is a whole other ballgame to tune compared to cm871 and newer, if jammed means it has a whole other turbo non VGT then the engine is probably even more fouled up because the bonebags that call them selves tuners out there are nothing more than copy paste trash tune artists. last truck i looked at before was tuned showed 740k on the odo after the tune it now has 420k....obviously tune was pulled from another truck then put into his with no consideration if they were even the same CPL numbers, also he was told it was set for 600/2050 after rawze calculated it was more like 750 and idk on torque plus the vgt had no idea how to control itself, the shop that did it charged him 5,000 for their hackery i fixed him up with a bit of help in 20minutes for free since the dpf was empty and their were blocker plates on EGR. almost every "Tuned" truck ive ran into that wasnt tuned by a tuner not from this forum has nothing but issue after issue and catastrophic failures. RE: black smoking cm870 - hhow55 - 12-31-2019 if jammed means it has a whole other turbo non VGT then the engine is probably even more fouled up because the bonebags that call them selves tuners out there are nothing more than copy paste trash tune artists. Hilarious!!! RE: black smoking cm870 - Rawze - 01-01-2020 (12-31-2019 )wellrun Wrote: hey guys ive had issues with a cm870 the was deleted and had the vgt jammed..after doing an overhual i am now noticing a thick heavy black smoke when accelerating and a lil loss of power...tried different tunes and same issue...could it be my overheads not right or turbo? your problem is that your dealing with obviously a bunch of complete morons who may be good at getting into the ecm,.. but know nothing about how a modern diesel engine works. Mommaburt or Unilevers -- they are the 870 veterans who do things the right way without shortcuts. -- and fix that goddamn VG TURBO, AND MAKE IT OPERATE CORRECTLY!. RE: black smoking cm870 - wellrun - 01-03-2020 I'm getting 12 volts at the air autcutor for the turbo.... Manual and wiring diagram said it should be 5volts also 10 volts on the signal side.... I also made my checks directly at the ecm also to isolate a wiring issues.... could be a bad ecm or those numbers are correct? |
