Cm 870 egr delete - Printable Version
+--- Thread: Cm 870 egr delete (/showthread.php?tid=5646)
Pages: 1 2
RE: Cm 870 egr delete - Volvo8873 - 01-02-2020
(01-02-2020 )Mrlaid Wrote:
(01-02-2020 )Magard Wrote:  Is egr cooler still on the truck.
Everything is removed and blocked off
That is a big no no... Number 6 cylinder is not getting the proper coolant flow. Is the stock turbo still on it??
RE: Cm 870 egr delete - Chamberpains - 01-02-2020
(01-02-2020 )Volvo8873 Wrote:  That is a big no no... Number 6 cylinder is not getting the proper coolant flow. Is the stock turbo still on it??
On a CM870 it's not such a big deal. It has a slightly different coolant flow that allows the removal of the cooler. I've been running mine for over 2 years with out one. On a cm871 or newer, that's a whole other ballgame. They must have the EGR cooler or bypass tube in order to keep proper coolant flow.
