| New fuel pump installation 2250. - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: New fuel pump installation 2250. (/showthread.php?tid=5652) |
New fuel pump installation 2250. - snailexpress - 01-03-2020 Quickserve stated fuel pump and crank shaft need to be timed before installation. My question is new fuel pump timed from the factory or i need to remove gear pump to set timing? RE: New fuel pump installation 2250. - JMBT - 01-03-2020 Mine was timed to the gear pump from the factory. If I remember right though, it was a couple years ago, there was a little mark on the pump drive gear that needed to be inline with a notch on the housing of the pump. I turned the gear by hand to align marks, then installed it. Didn’t do anything special with the crank. RE: New fuel pump installation 2250. - snailexpress - 01-03-2020 (01-03-2020 )JMBT Wrote: Mine was timed to the gear pump from the factory. If I remember right though, it was a couple years ago, there was a little mark on the pump drive gear that needed to be inline with a notch on the housing of the pump. I turned the gear by hand to align marks, then installed it. Didn’t do anything special with the crank.Pump has mark on the gear and I if my memory still serve it was on quickserve to align this mark with some other mark. Now quickserve procedure require special tool, remove gear pump and put this tool instead to align. Some places mention to align mark on the gear to left upper mounting bolt hole. I'm not sure. Hopefully Mr Hug will come here. RE: New fuel pump installation 2250. - snailexpress - 01-04-2020 So far found this [attachment=6034] Why quickserve abandoned this simple procedure and start using "special tool"? RE: New fuel pump installation 2250. - Hammerhead - 01-04-2020 (01-04-2020 )snailexpress Wrote: So far found this To keep "US" from believing we can do repairs ourselves, as the cost of buying a "special tool" for a probably once in a lifetime repair makes it cost prohibitive...in other words, to screw us! RE: New fuel pump installation 2250. - Rawze - 01-04-2020 (01-04-2020 )snailexpress Wrote: So far found this (speculation only): Because the 'certified techs/under-trained parts changers' are unable to properly align it without a tool to hold their hand? RE: New fuel pump installation 2250. - Toddmsc - 01-04-2020 Agreed! New pump installation should be straight forward. I would pin crank, line up pump as pictured above, and install. No special tools needed. Tbh I'm suprised they even give us access to quick serve. I'm not suprised it says you need a special tool. Cheers and good luck. RE: New fuel pump installation 2250. - JMBT - 01-05-2020 Yep, snail that is exactly what I did. Aligned it like the diagram you posted and slide it on. It has been just fine ever since. (About 200k now) |
