| Cummins ISM rough running - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Cummins ISM rough running (/showthread.php?tid=5653) |
Cummins ISM rough running - HFFT - 01-04-2020 I have a 2006 ISM running on cylinders 2&6 only. Getting voltage from 9 to 16 volts through injector harness. Injectors ohm ok and complete overhead ran. New turbo, alternator, engine position sensor and bench tested ECM at Kenworth dealer off of the truck. I have no accelerator pedal response and no pressure on oil pressure gauge but I am getting oil to top of engine. Anyone seen this or got thoughts? RE: Cummins ISM rough running - tree98 - 01-04-2020 Any codes? RE: Cummins ISM rough running - Signature620 - 01-05-2020 ISMs often misfire because of a faulty ECM but they usually have an active injector driver fault at the time. Does it have oil pressure related faults? |
