870 VGT actuator to test for boost leaks? - Printable Version
+--- Thread: 870 VGT actuator to test for boost leaks? (/showthread.php?tid=5678)
870 VGT actuator to test for boost leaks? - tree98 - 01-10-2020
Can I manually close the air operated actuator with the engine at an idle to create boost and check for leaks?
RE: 870 VGT actuator to test for boost leaks? - Unilevers - 01-10-2020
yes, it will be hard unless you remove the air actuator part though.
RE: 870 VGT actuator to test for boost leaks? - Lonestar10 - 01-10-2020
you wont wanna go full closed but 80%ish or so is what i do on the 871 with 1100rpm idle to check for leaks.
RE: 870 VGT actuator to test for boost leaks? - tree98 - 01-11-2020
I was thinking of using regulated shop air plumbed right into the actuator.
RE: 870 VGT actuator to test for boost leaks? - Lonestar10 - 01-11-2020
should be good spray the turbo side first as making 10-15psi at idle makes the hot side pipes smoking hot in a hurry.
