I’m new here and I have some questions. - Printable Version
+--- Thread: I’m new here and I have some questions. (/showthread.php?tid=5687)
Pages: 1 2 3 4 5 6
RE: I’m new here and I have some questions. - Magard - 01-17-2020
You need to physically verify the cac has no leaks. That’s not done on insite. Maybe you don’t need a new one. Save the 1500. If the one you have doesn’t leak then run it.
RE: I’m new here and I have some questions. - cowboycurtis - 01-20-2020
My Inline 6 showed up today. It says I need to register it. How do I do that?
RE: I’m new here and I have some questions. - Mattman - 01-20-2020
Contact the person you bought it from. They will give you the code#
(01-20-2020 )Mattman Wrote:  Contact the person you bought it from. They will give you the code#
I bought it off Ebay from China. They will give me a registration code?? Their is no paperwork in the packaging telling me where to get a code.
This isn't as easy as I thought it would be.
RE: I’m new here and I have some questions. - JimT - 01-20-2020
The seller page on ebay should have the contact info somewhere in the description. possibly in an email confirmation too.
Yes the Chinese hackers you bought it from will give you the code or set it up for you thru team viewer.
Like said click message seller on eBay and they will get you all fixed up
RE: I’m new here and I have some questions. - cowboycurtis - 01-21-2020
Big thanks to Running rough for setting up my Inline 6 and Insite software. He has been a huge help. His communication has been great. I would definitely recommend Running rough if you are needing some help with this. Thanks!!!
RE: I’m new here and I have some questions. - Running rough - 01-21-2020
Your best bet on getting your cm870 tuned properly is try and get a hold of Unilevers, mommaburt or mr hagg or Gearhead
